Dashboard URL Parameter settings disappeared
1173
08-30-2024 04:32 AM
Ellie_Linden
I’m currently using a Dashboard URL parameter to filter and zoom dashboards by protected area ID using a field called “OBJECTID_12.” The URL parameter is set, and the Dashboard appears to be functioning correctly, although when opening the “Settings” pane it shows that no actions are set (see screenshot).
I made a copy of the dashboard to explore further, and found that once creating that copy, the URL parameter actions were correctly showing in the settings. We need to continue to use the “live” version of the dashboard (rather than a copy), but as it is right now would not be able to successfully adjust the settings without the active settings being shown. Is this a known limitation/has this occurred for anyone else?
Ellie_Linden
I actually answered my own question: It turns out it just sometimes takes several minutes for the settings to load, but they are still present. This dashboard is complex, so it's possible that's the reason for the setting load delay.
