Dashboard - Series - How to Group Year of Birth into Age Groups
535
11-06-2025 04:44 AM
TheresaStratmann
I was wondering if someone could help me with the following task. I have a data set where each row is one person's answer to a questionnaire. One of the columns contains the year they were born in. In a Dashboard I want to track how many people within different age categories have filled out the survey, I want to do this using a bar chart where I can then use a value guide to show the target for each age group (same target for each group). So I my assumption is I need to use the data expressions option. In that,  I have managed to take my data and calculate the age, but despite a lot of Googling, I don't know how to now group the ages into age groups (e.g., 18-30, 31-40, 41-50, 51-60, >60) so I can feed this into the chart. Any help would be much appreciated.
var fs = FeatureSetByPortalItem(
    Portal('https://www.arcgis.com/'),
    '123456', 0,
    ['year_of_birth_please_write_full'],
    false
return GroupBy(
    fs,
    'OBJECTID', // unique ID field
            expression: '2025 - year_of_birth_please_write_full',
            statistic: 'SUM'
Neal_t_k
MVP Regular Contributor
One option would be to calculate that grouping with something like this
    '123456', 0,
    false
var currentYear = Year(Now());
var features = [];
for (var row in fs) {
    var birthYear = row.year_of_birth_please_write_full;
    var age = currentYear - birthYear;
    var ageGroup = When(
        age >= 18 && age <= 30, "18-30",
        age >= 31 && age <= 40, "31-40",
        age >= 41 && age <= 50, "41-50",
        age >= 51 && age <= 60, "51-60",
        age > 60, ">60",
        "Unknown"
    Push(features, {
        attributes: {
            BirthYear: birthYear,
            Age: age,
            AgeGroup: ageGroup
return FeatureSet(Text({
    fields: [
        { name: "BirthYear", type: "esriFieldTypeInteger" },
        { name: "Age", type: "esriFieldTypeInteger" },
        { name: "AgeGroup", type: "esriFieldTypeString" }
    geometryType: "",
    features: features
Then you can use the groupby settings and count statistic in your bar chart.
Neal_t_k
    '123456', 0,
    false
var features = [];
        age > 60, ">60",
        "Unknown"
    Push(features, {
        attributes: {
            Age: age,
            AgeGroup: ageGroup
    fields: [
    geometryType: "",
    features: features
TheresaStratmann
Thank-you so much Neal! This worked perfectly! I really appreciate you taking the time!
KenBuja
You can use the SQL CASE statement in the first GroupBy to bin the ages. This will also calculate the age group for the current year instead of 2025. The second GroupBy will count the number of each of the age groups
  '123456', 0,
  false
var sql =
  `Case
  When year_of_birth_please_write_full > ${Year(Now()) - 18} Then '<18'
  When year_of_birth_please_write_full > ${Year(Now()) - 30} Then '18-30'
  When year_of_birth_please_write_full > ${Year(Now()) - 40} Then '31-40'
  When year_of_birth_please_write_full > ${Year(Now()) - 50} Then '41-50'
  When year_of_birth_please_write_full > ${Year(Now()) - 60} Then '51-60'
  else '>60'
  end`
var grouped = GroupBy(
  fs,
  { name: 'Age_years', expression: sql, statistic: 'MAX' }
GroupBy(
  grouped,
  "Age_years",
  { name: "Age_Groups", expression: "1", statistic: "COUNT" }
TheresaStratmann
Thanks Ken, this is also an good option, in my case I just prefer the finer scale resolution of the output from the first solution. I appreciate the help and seeing how to do things multiple ways! The nice thing about coding 🙂
