Dashboard Lists - Cumulative Totals of Multiple Fields
2408
03-03-2020 12:55 PM
AndrewBeaman
We have built a survey in Survey123 to capture engineering notes & calculations in the field for gas service pipeline replacements and a supporting dashboard to calculate the totals from all the surveys associated with that job number. One of the items we capture is the asset we are retiring for accounting purposes. The asset consists of 4 fields in the survey (Pipe Size, Material, Vintage & Footage). Each service in a job will have it's own survey filled out so on a given job, there could be hundreds of surveys captured.
What we want to display in the dashboard is the total footage when each of the size, material & vintage match up. Here is an example of a few services:
   100' of 1/2" - Plastic - 1981
   50' of 3/4" - Steel - 1964
   75' of 1/2" - Plastic - 1986
In the dashboard, I want to display a list that would show the totals for those examples as such:
   200' of 1/2" - Plastic - 1981
   100' of 3/4" - Steel - 1964
We have been struggling with how to configure a dashboard list that would compile a total when the 3 other fields match. I hope that makes sense. Does anybody know a way to accomplish this?
Thank you for any help you can provide,
Andrew#
JessicaAltamira
Hi Andrew,
Great Question! There may be more than this option but I hope it finds you well. One way to display this report in the Operations Dashboard is by using a combination of the Category Selector + Indicator + List widgets. I've attached a 60 second video to show the final functionality so you can get creative with the layout. Although my features are lines, this can work with your Survey123 layer too. Hope this helps!
Category Selectors (Add a Header Widget to add 3 Category Selectors)
  • Job ID Category Selector Configuration
    1. Selector
Categories From: Grouped Values
Layer: Survey 123 Layer
Category Field: Job ID
Label: Job ID
Turn on None Option
Name: Job ID Filter
  1. Actions
             AFTER setting up ALL widgets come back and add Filters to:
  1. Vintage Filter
  2. Size Filter
  3. Plastic Count
  4. Plastic List
  5. Steel Count
  6. Steel List
  7. Survey 123 Layer
  • Vintage Category Selector Configuration
    1. Selector: Same as Job ID Category Configuration, just set to Vintage Field.
    2. Actions
  1. Size Filter
  2. Plastic Count
  3. Plastic List
  4. Steel Count
  5. Steel List
  6. Survey 123 Layer
  • Size Category Selector Configuration
    1. Selector: Same as Job ID Category Configuration, just set to Pipe Size Field.
    2. Actions
      1. AFTER setting up ALL widgets come back and add Filters to:
        1. Plastic Count
        2. Plastic List
        3. Steel Count
        4. Steel List
        5. Survey 123 Layer
Indicator by Pipe Material
  • Plastic Count Indicator
    1. Data
Filter Material = Plastic
Value Type: Statistic
Statistic: Sum
Field: Footage
  1. Indicator
Top Text: Retired Plastic (Color of your choice)
Middle Text: Add {value} field + ''ft''
  1. General
  • Steel Count Indicator
Same as Plastic, just replace everything with Steel
List Widget
  • Retired Plastic List
    1. Data
Sort by Vintage: Your choice
  1. List
Job: {JobID}
{Footage}' of {PipeSize}" {Material}{Vintage}
  1. General
  1. Actions
Flash Map(1)
Show Pop-up Map(1)
  • Retired Steel List
