Dashboard briefly shows all records even though “Today” filter is already applied by default
68
yesterday
Shravyagly
New Member
If anyone has encountered this issue or knows how to avoid the initial display of all records in dashboard, please share your insights.
Details:
I am facing an issue in the Forest Fire Monitor dashboard. The Acquisition Date filter is already set to “Today” by default. However, when the dashboard loads when refreshed, all forest fire data points appear on the map for a few seconds, and then the view updates to show only today’s records.
  • I have also enabled “Render only when filtered” on the Forest Fire map layer, but the issue still occurs during the initial load. We are using enterprise 11.4 version.
Expected Behavior: Since the Today filter is applied by default, the dashboard should load showing only today’s data, without displaying all historical records at any time.
Actual Behavior: Dashboard loads with Today filter already selected. All fire records briefly appear on the map
