Creating a new feature value in ArcGIS Dashboards based on populated attributes
1113
12-17-2024 01:24 AM
JustPete
I'm having some issues with an arcade expression. I would like to create a feature layer that returns a single value based on the sum of values where if an attribute is populated, it returns 1. There are 3 attributes that need to be scrutinised, thus, for the new feature layer to be presented in the Gauge widget, 100% would equal 3, due to the 3 attributes being populated.
// Reference the FeatureSet by Portal Item
var fs = FeatureSetByPortalItem(
  epportal,
  '*portal item ID redacted*', // Replace with your portal item ID
  0, // Layer index
    'LoADateSigned',
    'HoTsDateSigned',
    'GridApplicationSubmissionDate'
  false
// Initialize the count of populated attributes
var populatedCount = 0;
// Get the first feature (assuming you need one feature)
var featuredata = First(fs);
// Check if the feature exists
if (!IsEmpty(featuredata)) {
  // Check each attribute: Add 1 if populated
  if (!IsEmpty(featuredata.LoADateSigned)) {
    populatedCount += 1;
  if (!IsEmpty(featuredata.HoTsDateSigned)) {
  if (!IsEmpty(featuredata.GridApplicationSubmissionDate)) {
// Return the total sum of populated attributes
return populatedCount;
jcarlson
Summing fields could be done with a nice GroupBy, avoiding a time-consuming loop. A Data Expression has to return a FeatureSet, not simply a number, too.
// the featureset
  // your code here
// SQL expression to count populated fields
var sql = `CASE WHEN LoADateSigned IS NOT NULL THEN 1 ELSE 0 END +
CASE WHEN HoTsDateSigned IS NOT NULL THEN 1 ELSE 0 END +
CASE WHEN GridApplicationSubmissionDate IS NOT NULL THEN 1 ELSE 0 END`
// group it, sum the three fields if not empty
return GroupBy(
  fs,
  'objectid',
    expression: sql,
    statistic: 'SUM'
- Josh Carlson
Kendall County GIS
jcarlson
// the featureset
  // your code here
return GroupBy(
  fs,
  'objectid',
    expression: sql,
    statistic: 'SUM'
- Josh Carlson
Kendall County GIS
JustPete
Thanks Josh, this has worked well, only issue is that I can't apply category selectors to scrutinise the data, is there a quick way of being able to incorporate this?
JustPete
Just worked it out, thank you so much Josh!
jcarlson
Sure! In order to interact with your Data Expression, we have to make sure that every field you need is included in the list of grouping fields.
return GroupBy(
  fs,
    'objectid',
    'some_category',
    'some_other_category'
    expression: sql,
    statistic: 'SUM'
Then your other attributes will be in the output for interactions.
- Josh Carlson
Kendall County GIS
