I have four multiple choices that are unique grant numbers and want to combine two by two and give them new names. I have tried but as I am new to Arcade, couldn't manage to do it. Any idea will be appreciated.
| 15-GR-1060 | CWD |
| 20-GR-0040 |
| 16-GR-1053 | WAD |
| 21-GR-3012 |
Here is what I have for now, but I want them as two separate categories, CWD and WAD:
Here is the expressions:
var portal = Portal('https://arcgis.com/');
var EODFAR = GroupBy(
FeatureSetByPortalItem(portal,'49610a8451174e65b413509ff03196b4',0,['*'],false),
['field_1','fatype','field_82'],
{ name: 'EODFAR_ID', expression: 'field_2', statistic: 'COUNT' },
var CWD = filter(EODFAR, "field_82 = '15-GR-1060' and field_82 = '20-GR-0040'");
var WAD = filter(EODFAR, "field_82 = '21-GR-3012' and field_82 = '16-GR-1053'");
var combinedDict = {
fields: [
{ name: 'Choices_WAD_CWD', type: 'esriFieldTypeString' },
{ name: 'Report_date', type: 'esriFieldTypeDate' },
{ name: 'count_of_ids', type: 'esriFieldTypeInteger' },
{ name: 'advisors', type: 'esriFieldTypeString'},
geometryType: '',
features: [],
// Loop through each of the FeatureSets
var i = 0;
for (var f in EODFAR) {
combinedDict.features[i] = {
attributes: {
Report_date: number(f['field_1']),
advisors: f['fatype'],
count_of_ids: f['EODFAR_ID'],
i++;
// Return dictionary cast as a feature set
return FeatureSet(Text(combinedDict));
@DavidNyenhuis1
