Change the extent of the 'Select a tab' pop up when using stacked tables
223
06-26-2025 01:17 AM
MattHowe
I have a dashboard that uses around 15 stacked tables meaning a user could either scroll through them or use the 'Select a tab' pop up. I've noticed that the tables listed in the pop up run down off screen and so can't be selected. Is there a way to ensure all tables are visible for selection in the pop up?
The image included should have a few more tables visible and there is no scroll option in the Select a tab pop up.
Edit - it is possible to use the cursor keys and go further but would be better with the mouse wheel or a scroller in the window.
