Change Map Extent in Dashboard using URL Parameter
1397
11-21-2024 06:11 AM
jchadwich1
I'm working on a dashboard in ArcGIS Online and need to add a parameter to the end of the URL to the dashboard allowing filtering options and changing of the map extent for multiple maps within the dashboard.
An example of what I'm trying is shown below. In advanced formatting for the list element, I've created the URL by concatenating these two lines, then returning the URL.
ext="-80.6,40.6,-70.7,47.7"
"https://portaluser/apps/dashboards/96rt5248ym357825gr548r98l#p1=ext"
The link opens up to a second dashboard, where I've set up p1 with URL parameters to filter the maps and several other elements. However, I don't see an option to change the map extent. I'm sure there's a way to do it as it's mentioned in the geometry parameters section on this page. Does  anyone know if I've done something wrong with the way I've structured the URL or perhaps if I've overlooked the option to change the map extent in the linked to dashboard?
lzk222
Not sure if I fully understand the issue, but the extent needs to be set up like so:
"https://osit.maps.arcgis.com/apps/dashboards/ead6daa4485542ca9cf46a4e2d5bd8a6#subawardee={subawardee_name}&program=BEAD&extent={xmin},{ymin},{xmax},{ymax}"
Extent configuration should look like this:
Not sure how long this link will work, but this is what it looks like in action.
https://osit.maps.arcgis.com/apps/dashboards/ead6daa4485542ca9cf46a4e2d5bd8a6#subawardee=AT%26T&prog...
