Calculating the Sum of a polygon attribute that is touched by a filtered polyline
208
08-06-2025 11:33 AM
RobertBorchert
Honored Contributor
Don't know if this is possible outside of ArcGIS Pro
I have a polygon layer that contains power information as a Number (double)
I have distribution lines coming out of substations that can be distinguished by Substation Name and Feeder (via windmil data)
In a Dashboard, I would like to be able to filter the line by selecting substation and a feeder using filters. Then any of the hex polygons that intersect those filtered lines the dashboard will calculate the Sum of an attribute column.
