Allow Month or Year Choices on Date Selector
2473
6
08-02-2023 12:57 PM
Status: Open
ChelseaRozek
MVP Regular Contributor
Please allow more options on the Date Selector widget in ArcGIS Dashboards. Like being able to exclude time, I would like to further simplify the selector for my users by allowing them to create either month year ranges (Jan 2020 - March 2023) or just year ranges (2020-2023) on a datetime field.
Right now, the only workarounds are to manually create these custom time ranges (very tedious and not dynamic for the future) or to create a whole new field with just the year and use a category selector. I'd rather not maintain redundant columns nor set up automation to populate it. This also wouldn't help set up month year ranges as they would be independent from each other.
6 Comments
PanGIS
I kudoed it, not sure if there is another way to upvote it.
I would really need to have a monthly selector.
I have to add it manually every month.
Last month the customer called because in panic that he had lost all data... but I had only forgotten to add the latest month to the selector list 😂
ChelseaRozek
@PanGIS Kudos and a comment with your use case is perfect, thanks!
JulianMcCoy
This would be really useful for my use case as well. It seems so obvious that I was convinced there must be a standard way to do it and was shocked to find there wasn't
AnnaJose
This would be very useful for us as well
SandraLuken1
ChelseaRozek
@SandraLuken1 Yes, thanks for the links. That will be much more user-friendly in my dashboards. I appreciate that there is the option of numeric, short, or long text for the months and setting the entire range to be dynamically dependent on a field's values so we don't have to recalculate it later.
