When will extended token be implemented?
3222
15
12-28-2022 08:50 AM
erica_poisson
Hi -
I know Esri has been working with Microsoft to extend the token life from 14 to 90 days with the ArcGIS connector. When will that be implemented? I'd thought it was included in the December release, but am finding I still need to refresh tokens every 14 days. I may have misinterpreted what I read.
Any insight would be appreciated.
Thank you,
Erica
SeanKMcGinnis
After a very long publication freeze on Microsoft's side, we got notice yesterday that the certification has been completed and it will be included in their next deploy package. This means it should be moved out of Preview into General Availability in the next three to four weeks and then promoted to GCC in four to six weeks after that.
-sean
Sean McGinnis - Principal Product Manager, ArcGIS for Microsoft
RobertAnderson3
MVP Regular Contributor
I came looking for the same information, hoping there's an update on this soon.
SeanKMcGinnis
-sean
RobertAnderson3
Is this a 90 day timeout as Erica mentioned or removing the timeout all together like the Survey123 connector?
erica_poisson
@SeanKMcGinnis  - thank you!
Will there be any sort of announcement made when this is available in GCC? Also, will any change be necessary to existing flows for this to take effect?
Thank you!
Erica
SeanKMcGinnis
@RobertAnderson3  - It will be a 90 day timeout because of a difference in authentication. Here is a post that details the difference between the two authentication methods and why it is occurring.
-sean
RobertAnderson3
Thank you for the quick reply and the additional info!
SeanKMcGinnis
Good day all - I wanted to share an update in regards to the 90 token expiration. The ArcGIS Connector for Power Automate has been deployed to many different regions. As of this morning, the last two regions for it to be deployed are the US and UK. I will update the thread when I get notice.
-sean
SeanKMcGinnis
I have not gotten the notification from Microsoft that the connector has been deployed to the US and UK regions, I did just check Power Automate (in the public cloud) and the new capabilities are in there. I will continue following up with them to get an update as to when it hits the GCC tenants.
-sean
erica_poisson
Hi @SeanKMcGinnis  - any update on the ETA for this in US GCC?
Erica
