Need Help Converting Coordinates in Power Automate for ArcGIS Workflow
815
12-11-2024 12:50 PM
JonEric_Eubanks
Hello,
I’m trying to convert coordinates in a Power Automate workflow that integrates with the ArcGIS connector. Here’s the setup:
  1. I’m using the "Create Point Geometry" action nested in a For Each loop to process a list of latitude and longitude values (decimal degrees, WGS84 - EPSG:4326).
  2. I need to reproject these coordinates to State Plane Illinois East (EPSG:3529).
  3. I am unsure which step to begin with first. I created the points, but they are in a different projection, so they are not in the correct location.
Thank you for your assistance!
EamonnDoyle
Hi, the only way I have found to do this is to use the ArcGIS Geometry Server and pass the input and output EPSG and the co-ordinates into the 'project' operator. Unfortunately there is no connector for this so you need to use the http/s connector to call the Geometry Service and pass your variables in the Headers field as key-value pairs.
https://<your-arcgis-server>/arcgis/rest/services/Utilities/Geometry/GeometryServer/project
