ArcGIS Connector issue? Unable to synchronize replica
1174
05-08-2023 06:26 AM
DominicRobergeIADOT
Hello
I created a simple flow 3 months ago using the arcgis Connector. When a record is created, get some of the information and send an email. Everything was working fine until May 1st (as of Friday April 28th, flow was working as expected, Then starting May 1st, flow stopped working returning following error:)
This is the basic flow:
I have tried with different feature layers and ALSO with different office 365 sites and I am getting the same results.
Any ideas?
Thanks!
ahargreaves_FW
Is the layer in question part of a Collaboration or some other replication process?
I have a set up whereby I collaborate data from portal to AGOL, and when that occurs and a new feature is created in AGOL it triggers an email similar to your flow. It broke recently as my collaboration broke due to a schema change. I had to wipe out and recreate the collaboration AND build a new flow - not recreate the existing one but make a whole new one. My understanding is that the Flow webhook (ChangesURL) includes a reference to a specific version...hence why you need to recreate a fresh new flow.
DominicRobergeIADOT
nope, just shared with the Org and with the following settings:
SeanKMcGinnis
@DominicRobergeIADOT - my suggestion would be to submit a support ticket so we can get the right people to directly work with you. When you get a ticket submitted, please email me at smcginnis@esri.com with the ticket number so I can follow along with the incident and see the detail of what you are encountering.
-sean
Sean McGinnis - Principal Product Manager, ArcGIS for Microsoft
DominicRobergeIADOT
10-4 will do that right now
MeganHicks
Hi Dominic, I had the same replica error a few weeks ago. Recreating the feature layer fixed the issue for me. Good luck!
