Unable to submit Survey123 form with Domain fields which are auto populated from ArcGIS Collector using custom URL Schema.
813
01-28-2021 09:23 AM
sayamshivakumar
We are configuring the Survey123 form using ArcGIS Survey123 Connect, using feature service.
We are Auto populating the domain fields(drop down fields) using custom URL schema through collector. The survey123 app is taking the domain description instead of domain code While auto populating through collector using custom URL Schema. With This issue  we are unable to submit the survey123 from.
The same scenario is working fine when we are navigating form any browser in ArcGIS portal. but when we navigating from collector, we are facing issue.
Any Quick response is much appreciated.
Thanks in Advance.
