Trouble downloading data from AGOL
4774
18
08-28-2015 09:03 AM
AlexBullen1
I am having trouble downloading my data from a recent Collector project. It is a point layer with picture attachments and about 1,800 points.
The data is contained in the "Inventory - Tree Inventory" feature layer.
There is no download button on the page for this layer.
How do I download the complete dataset to use in ArcMap?
AlexBullen1
Sorry but this is getting above my head. Here is a picture of the service URL. It has an ID of 0.
I can also tell you that I am not the original owner, because when I go to the root of the service URL above it takes me to all the feature services that my predecessor published before we implemented a new server & database system. This person is no longer here, no longer has a login, but we still need this data.
"Inventory (FeatureServer)" is the layer that we need to download.
RonKnepper
Can you share the bottom of your description page?  Its odd, I have never had that happen unless I was not the owner.
AlexBullen1
Ron, the bottom of the description page is in can be seen in the second photo of my original post - is this what you're referring to?
Is there a chance I'm not the "true" owner? Our previous admin uploaded this service, and I've since switched everything over to my ownership. She doesn't even have a login anymore.
RonKnepper
Ah sorry I was looking at the post in another section and it didn't show me the bottom but I see it how.  below is what one of my services looks like and you can see more options there as well.  Parks_TownofSuperior is showing as the publisher, is that your signon?  I was assuming it was but that is the user who published the service and if you are logged in as that user I would expect the export to be available.  If not I suspect that is the issue.  If that is not you then there is an option (Seen in my snapshot) to enable export data for other users.  If the publisher enables that it might resolve your issue, though I am not sure what export options it gives as I don't have access to one setup like that which I do not own.
RonKnepper
Also if that is not you and enabling the export does not give you the options needed, AGOL has a new feature that allows the admin (and only the admin) of your AGOL account to create a group that gives all members the ability to edit items shared to the group which also might resolve the issue
Share items—ArcGIS Online Help | ArcGIS
AlexBullen1
Unfortunately neither of these solutions work. Whether I log in as the admin or using the parks login, I cannot download this data. The dataset is shared with groups that have editing capability and still there is no download button. Everything is there in AGOL but as the admin I cannot download the data.
RonKnepper
I am wondering if it is something in the way that person who left initially published the services.  Its very odd the setup.  How much data has already been collected?  I would try calling ESRI tech support who should be able to help more.  I am at a loss on this, if they cant help the only option would be to recreate the feature service and then republish.  You should be able to get out the existing data but it would be a pain to then get it back into your service.  Have you used Ops Dashboard before?  There are export widgets in there that let you pull out data in csv and attachments separate which you could then import back in (attachments would be the pain) and republish then use the new feature service going forward.
AlexBullen1
I have filed a claim with Tech support. 1,800 points with pictures have been collected and organized over 3-4 weeks. Moving forward, the service does need to be published properly, so I would have no problem with dismantling the service in order to get at the data. We do need the attachments as well.
RonKnepper
Ah sorry, hopefully ESRI gives you an answer.  the points should be ok, I know you can create the fgdb and import your data but the attachements will be a pain.  I dont know an easy way to do that.  Hopefully there are no related tables which would add to the trouble.
