the request timed out
3481
13
09-10-2014 02:26 PM
ScottBallard
anyone get this message when using collector to access Portal?
JürgenAchilles
Hi Scott
can you provide more detail. At what point is collector timing out. When you open, load a map or enter a point etc...?
ScottBallard
when i attempt to sign in. Collector successfully validates I have the correct web address for Portal, then I sign in and it times out. I have used mutliple logins all with the same result 'The request timed out'
Thanks for responding
JürgenAchilles
Scott,
are you a member of the Collector Pilot Group?
If not check with GIS Support‌.
Regards
ScottBallard
No I am not….
GISSupport3
Hi Scott Ballard
Can you connect to the Portal via a web browser?
ScottBallard
yes i can
GISSupport3
Can you connect to the Portal via a browser on your mobile device?
Does the Collector App released last week make a difference?
ScottBallard
Yes I can connect to Portal via my browser on the tablet.
It’s the latest version of Collector
GISSupport3
I assume you are on Android?
Via your browser, login to the Portal and then click "My Organisation"
Look for your Name.
Confirm your Username
Use the exact Username as the login via the app.
See what happens.
