Synchronize in Collector for Arcgis
1486
05-19-2020 02:29 AM
MagalyClément-Zaber
Collector for Arcgis 20.2.0 Build 2952
Portal 10.5.1
I want to test offline use of collector. I tested with a simple feature layer. No error message when I synchronize but my updates are not in the webmap in Portal.
Any ideas ?
Thx
ThomasJones1
Hello Magaly CLEMENT‌,
Is the feature layer you are editing referenced or hosted? If you are using a referenced feature layer are you using versioning? If so you may need to reconcile and post your edits before seeing the changes reflected in the web map.
Reconcile and post edits to a version—Geodatabases | Documentation
Thomas.
MagalyClément-Zaber
Hi, Thanks for the response !
My fetaure layer is referenced. I am not using versioning but it's a good idea !
I can't modify this parameter :
I'll test with another data to see if it's because of that !
Or maybe test to disable archiving ?!
Magaly
MagalyClément-Zaber
Nope, Archiving is required to synchronize
