Sync Error - An error occurred while synchronizing edits - Operation Rollback
1504
08-16-2018 10:04 AM
JAVIERVARA_SANZ
We are having issues with an offline collector web map. Users will basically have to drop a point in the map, answer four simple questions, and attached anywhere from 1 to 6 pictures.
One of our users has contacted us reporting that he is getting the following error: "Sync Error - An error occurred while synchronizing edits - Operation Rollback". Please note this user has been successfully submitting data in the past using the same web map.
We've tried updating the settings so to Push Only data recently entered, but same issue when trying to sync the information. Preferred attachment size is already set to large, so no changes here.
I've searched for similar threads, but it looks like no potential solution is in place other than recovering the data from the device. Our alternative is input the data directly on AGOL and attached the pictures there. However, this doesn't sound like a good workflow if we continue to get the same error over time.
Any suggestions or solutions will be highly appreciated.
deleted-user-J5uS64sC7pwm
Having the same problem. Collector and Ipad Pro.
Launched Sign Inventory Collection with our Highway Department now they can not sync offline collected data???
