Symbology to change in collector by script
562
10-04-2017 08:30 AM
GeorgeKatsambas
I am publishing editable feature map services with a predefined symbol set, we also have an editable attribute that when populated a python script ran against the map service and changed that symbol to a check mark. Is there anyone that can help with why this script does not work anymore, i would need to message you privately.
MicahBabinski
Hi George,
There's not enough information in your post for anyone to offer you assistance. Here's what I'd recommend:
  • Explain how your process is supposed to work
  • Clearly state what the problem is - don't forget to give an example!
  • Post your code using code formatting ("syntax highlighter" in the format menu)
Micah
