Strange Error with SQLite
2856
09-09-2021 09:11 AM
JackSelzer
Hello,
I am using a hosted feature layer to collect data in Esri Field Maps (21.2.3) or Collector (21.0.2)
The hosted feature layer contains three layers; polylines, polygons, and point features.
I have no issue placing polygon, or polyline features, but when a second point feature is submitted, it fails and is followed by; Error SQLite constraint violation.
JakeSkinner
Esri Esteemed Contributor
@JackSelzer this will probably require troubleshooting:
  1. Try publishing the data as a new hosted feature service and see if the issue remains.
  2.  Try publishing new data as a hosted a feature service and see if the issue remains.
MikePowers
I was getting an error a smidge longer (arcgis.runtime exception, SQLite constraint violation. SQLite 19..... something like that) republished a new feature service and now I just get the same sleeker error as the original post.
JeremyBridges
We see similar errors when using Runtime with sync replicas. Seems like Runtime might need a better error message. An FYI. Stack trace:
- at Esri.ArcGISRuntime.ArcGISException.HandleCoreError (RuntimeCoreNet.GeneratedWrappers.CoreError error, System.Boolean throwException)
- at RuntimeCoreNet.GeneratedWrappers.Interop.CheckError (System.IntPtr errorHandle, System.Boolean throwOnFailure, System.Runtime.InteropServices.GCHandle wrapperHandle)
- at RuntimeCoreNet.GeneratedWrappers.CoreArcGISMapImageSublayer.get_Table ()
- at Esri.ArcGISRuntime.Mapping.ArcGISMapImageSublayer.<get_Table>b__43_0 (RuntimeCoreNet.GeneratedWrappers.CoreArcGISMapImageSublayer c)
- at Esri.ArcGISRuntime.Internal.RuntimeLazy.Make[T,U] (T& target, System.Boolean& initialized, System.Object locker, U factoryParam, System.Func<T,T1>[T,TResult] factory)
- at Esri.ArcGISRuntime.Internal.RuntimeLazy.Get[T,U] (T& target, System.Boolean& initialized, System.Object locker, U factoryParam, System.Func<T,T1>[T,TResult] factory)
- at Esri.ArcGISRuntime.Mapping.ArcGISMapImageSublayer.get_Table ()
ArmstKP
I am getting the same error, when trying to delete a feature in the Field Maps app...
