#I am taking CSV files of points and adding X, Y, I then copy the files to ArcSDE and use arcmap to symbolize and publish as a map service. This map service is then used in the colllector app based on a web map that allows only 1 field to be editable, however, when the map is opened as a web map through a browser all fields are editable. Is there a way to fix this.
