open the Collector by a url with parameters
3324
06-03-2014 01:19 AM
YigalMuntner
Hello,
Is it possible to open the Collector by a url with parameters?
For example: I want to send an SMS with a url, so that the collector will open and zoom directly to a specific feature.
When a feature class has few hundreds of points, I don't want the field crew to start searching the map for an event.
Regards,
Yigal
Kylie
by Esri Regular Contributor
Hi Ben - In the new Collector app (released on iOS and in beta on Android) you can now pass in a search parameter with Collector links.
You can learn about the Collector links here: Deploy your map—Collector for ArcGIS | ArcGIS
And this section has some examples of using the search parameter: Deploy your map—Collector for ArcGIS | ArcGIS
Esri Education Team
RussRoberts
Esri Notable Contributor
Currently this is not possible. We are building in support for feature search that will mirror what Explorer for ArcGIS has today. You will be able to search features that have been configured correctly in the web map and using the search tool you could find those features.
Russ
BenNadler
Hi Russell. Has this been implemented? the ability to pass the FIND parameter for a specific feature attribute?
Kylie
Esri Education Team
