Hi
After hitting issues detailed here (https://community.esri.com/message/874318-collector-classic-and-current-timeout-issue-on-download ) I've managed to sideload the basemaps onto the iPad (using the newer version of course) but I can't change the default map of my published map, so when I go into the Download screens it is going back to trying to download from the server (which is failing) - so, how do I tell Collector I only want to download the feature data?
I've added this as a new question as I think it can be viewed in isolation from the other one, as even if I could download in the normal way I would want this ability
Cheers
ACM
Solved! Go to Solution.
