In this initial release the app only supports one basemap at a time. If you don't mind me asking what would you be using the 2 basemaps in 1 downloaded map for?Thanks!Russ
You could set the top basemap layer as an 10.2.2 ArcGIS Server tiled map service with export enabled and have it as an operational layer and then use the topo layer as a basemap layer and you can have both right now and download it as one map.Russ
I also have a topographic basemap and an aerial photo basemapt that I would like to switch between in collector.
Hi Russ. can you expand on this? We need an offline map showing our assets and imagery. Is it best to bake a single tpk, or can we have an offline asset tpk along with switchable offline basemap tpks?
You can side load both onto the device and if they are within the same extent you can change the basemaps while offline or have one setup as a hosted service and download that with the map and have the other one side loaded and you will see it in the basemap gallery.
