May we have a copy of the Esri geodatabase?
531
07-05-2013 08:34 AM
DonBarker
The Collector App sample/tutorial for damage assessment includes dropdown menus (pick lists) for the mobile app.  Other threads in this forum explain that for dropdown menus, you have to publish the map service from ArcMap, with a geodatabase that makes use of subtypes and domains in the fields.  The map service is here:
http://sampleserver6.arcgisonline.com/arcgis/rest/services/DamageAssessment/FeatureServer/0
Could Esri publish a copy of the damage assessment geodatabase (as file geodatabase?) for all of us to use and modify?
RussRoberts
Esri Notable Contributor
Here is the sample data used in the damage inspection map:
http://arcgis.com/home/item.html?id=95ac234a9da44f5eafeaff2042810944
DonBarker
Excellent!  Thanks for this pointer.
