Is there a way to define the offline work area based on a polygon I provide?
2606
01-21-2016 07:28 AM
MikeFrates1
For example, I have several maintenance areas that I need inspected.  Instead of defining the work area using the built-in default rectangle, can I define the work area using the maintenance area polygon?  My research indicates no, but I wanted to verify.
RussRoberts
Esri Notable Contributor
You currently cannot do this today. There are plans for a pre-planned workflow where you can define the work areas before hand and the field users can download those packages instead but that will be coming in a future release and I do not have a release date for you right now but can update the thread when I have one.
RussRoberts
MikeFrates1
Thanks for the prompt reply and answer Russell.  Yes, please let me know when you have an idea of when this feature will be available.
