iOS Collector BUG - Field Order
4006
04-08-2015 12:31 PM
BledarBirbo1
ArcGIS collector 10.3 for iOS does not honor AGOL attribute order, nor the field order that has been set from the arcmap for the layer that is published.
Tags (1)
PaulCone
I haven't found this to be the case.  Can you post an example?
BledarBirbo1
Hi Paul.
What do you mean to post an example ? How can i post it if there are 5 systems involved in the data-flow.
Here is some more info.
1-) Added a new filed to an existing Geodatabase feature class.
2-) Promoted that field order on the MXD (via arcmap)  and republished to ArcGIS server.
3-) AGOL was not showing the correct order.
4-) Promoted again that field through Popup Attributes Order.
5-) Downloaded to the collector. (The field was showing in the END)
