How to Capture Barcodes with Collector on iOS Devices
4949
07-03-2014 01:54 PM
JenniferJacob
Do more with Collector using barcode scanners | ArcGIS Blog
Utility meters, poles, pipes, traffic signs – the fixed assets that you manage inside of the ArcGIS platform are not only mapped but are often tagged with durable, weather resistant barcodes that uniquely identify each asset inside of an asset management system. Quite often we are asked if Collector for ArcGIS running on a smartphone or tablet can be paired with a barcode scanner so that as you map asset locations you can capture the barcodes placed on them as well…
JenniferStarbuck1
Is there a solution where I can take a picture of the barcode with my iPhone and the information  is saved in collector?
SanneMikkelsen
