How can I edit a field in Collector to show as text?
1231
10-03-2019 08:40 AM
Tammy_LynnSchaefer
I added a field in my Collector map and changed the Type to string.  When the data collection and map are complete, I want the ability to download the data into a an Excel spreadsheet.  For the field I added, I need the "Type" to be text.  The field that I added was "Type of Asset" and I want to see each type as text instead as numbers; i.e., fuel tank, when I convert to Excel.
Thanks.
Tags (1)
DougBrowning
MVP Esteemed Contributor
Use this button in Excel to import the CSV.  It will let you pick the field type so you can force it.  I use it for our keys all the time since they get converted to scientific by excel.
DougBrowning
Tammy_LynnSchaefer
Thanks for the response, but I need more clarification.  In order to get an Excel worksheet, I took the attribute table to an excel table in Pro (table to Excel function).  Once the data is in Excel, I chose Data and changed "From Text/CSV" but it wants me to import the table I'm in.  Sorry I must be missing something?  Thanks for your help.
DougBrowning
I assumed you were exporting to CSV.  Try that.  This is an excel issue not an Arc issue.
Unless you are talking about domain values?  So you have domain that has a 1 = Type X, etc?
Tammy_LynnSchaefer
Thanks for your help!  It's working now.
