okay, so i used to be able to add attachments in collector with my android 4.4.2...I get an error message now..
So I tried to follow my steps in creating an app and making it editable.
I have a feature layer in AGOL that appears to be editable, as I can add a point in collector, but when i add a picture either from the camera or gallery, the picture fails to load.
So, in AGOL, the directions say to Click MY CONTENT, okay i did, Click the feature service name, I did,
then "
You can enable editing on a hosted feature layer if the people who access it need to edit the feature geometry or attributes. Follow the steps to edit web layer details, check Enable editing and allow editors to, and then choose what types of edits can be made.
You can choose among the following editing options:
I cannot find "Enable editing and allow editors to"....
What am i doing wrong? Where is this check box????
I have a feeling my problem is web server based, but I need to check the basics first...
Clint
Once you are at your feature service page, click on EDIT. This is located below the picture. Once you have clicked that, go to the bottom and "Editing" pops-up.
Thank you Tim for the response,
I remember months ago seeing those options under properties, but now i dont see those
Could i be having browser problems???
Can you attach a screenshot of your browser page?
Hi Tim,
Here it is
Clint,
what version of ArcGIS Desktop are you using? I noticed that my feature layer has (Hosted) behind it and yours doesn't.
Tim
Hi Tim,
10.2.2
Did you create this feature service in ArcGIS Online or in desktop?
Desktop, and published like this....(I made a new feature service to get these notes, but its the same steps i used before...but I have to be missing something...)
File, Share As, Service...Publish a Service...Choose my Connection and Service Name, Use existing folder,
and Under Capabilities I added Feature Access (side note - Mapping tab doesnt have "edit" anywhere as a check box)
then i analyze and publish....
I go to Server Manager (Windows version) and its there...
Seriously I was able to add attachments months ago, but yesterday I jumped back on my project testing and now i cant....
Thanks again for the help
This is weird, it should be working the way you described it. Sorry I couldn't be more helpful.
