Has anybody else experienced issues with collector loading map on galaxy tab s3. works fine with iPad using the same login. when i try with the galaxy it just spins
6574
40
12-01-2017 10:57 AM
ErikBlake
Has anybody else experienced issues with collector loading map on galaxy tab s3. works fine with iPad using the same login. when i try with the galaxy it just spins.
ErikBlake
Sounds good. Thanks Kevin
ErikBlake
Hi Kevin
In an unrelated issue that just came up today. Our iPad users starting experiencing an issue with collector where when they zoom in on their map collector crashes. We tried it on several iPads and my iPhone it did the same thing on all our devices. Have you heard anybody else experiencing this. Like I said it just started today. Collector was working fine up until today. Thanks
KevinBurke
Hi Erik,
Thanks for reporting this issue. No I haven't heard of this issue yet. Can you please provide more detail?
- Are you working with maps that include a custom basemap?
- Are you working with AGOL hosted feature services or your own Enterprise services?
- Can you elaborate on how they are zooming into the map?
Thank you for that information.
-Kevin
ErikBlake
Yes custom basemap. However I just tried switching to an esri baemap and when they zoom in using the "pinch" method on the screen it crashes using either basemaps. We are using our own enterprise service, I built a web app with web app builder (Non-developer version) with the batch editor widget and when we use that it works fine no crashes when zooming in tight.
ErikBlake
Kevin.
In regards to the post I made today. i found out the culprit. It was a parcel layer that I added to map. Removed it, all seems fine now.
KevinBurke
That's great Erik, glad you solved that one!
Still waiting for more info on the Tab S3. Will keep you posted.
-Kevin
ErikBlake
Kevin
Any luck with the Tab S3?
KevinBurke
Hi Erik,
Sorry for the delay, however I still don't have a Tab S3 to test with. We've requested to get one. So at this point, I am just waiting to receive it.
I will let you know once I do.
When you last performed the factory reset, prior to that, did you uninstall Collector first? I wouldn't think this should matter to the issue, but I am just curious.
-Kevin
ErikBlake
Kevin
Thanks for the update. And Yes I did.
ErikBlake
Kevin
Any Luck? would really like to get this tablet deployed
