EOS Arrow 100 with Field Maps - no GPS location
5862
10-31-2021 09:16 AM
CurtKleist
I recently just got a EOS Arrow 100 but GPS location/position is unavailable and no satellites. I have shut off and on multiple times, it seems a small fix but I just purchased new. I am using an IOS device (ipad mini) and got bluetooth connection through settings and EOS Tools Pro app but no position. I did try with my android cell and received the same issues, but would like to get resolved with an IOS. Any advice? I did reach out to EOS but would like to get resolved asap as I have upcoming field work.
Tags (3)
ZachCranney
Hey Curt, I'm having the same problem. Did you manage to find a solution?
CurtKleist
Yea make sure the antenna is connected correctly with the quick release.
CurtKleist
Did you ever get it resolved?
ErikAllard
posting in case someone else has this problem, but I'm working with a dozen arrow gold, and arrow gold+, most boot up and start seeing satellites almost right away, but I have 3 that take a few minutes to start seeing them. If you've confirmed the antenna connection is tight on both ends, trying setting it up and just leaving it out and alone for a 5-10 minutes to get it going.
