Edit Collector Pop-up Ribbon Attributes
6696
11
01-14-2014 01:25 PM
CCWeedcontrol
This App is working great for my departments needs! My hat is off to the development team. I have another little issue though. Is there a way to edit what is displayed in the attribute ribbon at the bottom of the screen when you select an item? Refer to attached picture. Can I select a certain field to be displayed for either title or sub title? I've been able to customize the title for the full pop-up using the edit pop-up tool in AGOL, but I cannot get it to change on the collector pop-up ribbon.
John
RussRoberts
Esri Notable Contributor
Currently there is no way to show the popup by default. If you don't mind me asking what are you currently using the Collector app for?
Russ
SeanTondre
Thanks for the response Russ.  We are currently using the collector app to collect/manage/view real-time field collected data to provide efficient biological monitoring for construction projects.
