Copying a Runtime GDB from iPad to FGDB Error
8234
11
06-12-2015 03:00 PM
JasonThoene1
We were having problems syncing data from our iPads to AGO a while back.  To back up this data, we copied the .geodatabase file and all associated data from the iPad to our local server.  It was my understanding that I would be able to bring the data back in to a FGDB using the 'Copy Runtime Geodatabase to File Geodatabase' tool, but it seems not to be the case.  I receive 'Error 001730' when I try to run this tool.  Using ArcGIS 10.3, Collector 10.3, and AGO.
Is there some setting I need to enable in order for this tool to work?
Jason
FarleyKlotz__Canada_
I had a very similar issue.  Runtime .geodatabase from iOS with sync issues.  ArcGIS 10.6.1 would return the Error 001730 on attempting the conversion.  Data was viewable in ArcGIS Pro 2.4 so I tried the ArcGIS Pro 'Mobile Geodatabase to File Geodatabase' tool and it was successful in converting the data.
GustavoOrozco
Hi Farley, it worked for me, thank you so much!
