Collector unable to download the map
3712
03-20-2019 09:56 AM
by Anonymous User
Not applicable
Hello,
   We are currently having issues with our field crews being able to download "any" map from ArcGIS Online within the new collector and/or the collector classic versions. All of the collector maps had been previously working without any issues for months, but now we are receiving the following error below -
"Map Download Failed
Unable to download the map."
Under the "more" portion of the error I am seeing this message "Unable to create replica. Please check your parameters. Create replica internal error."
I have tried the following -
1). Opening and turning off the offline mode, saving, opening the map within both the web browser and Collector, edit some data, then saved, switched back on the offline mode, saved, and attempted to download a new offline map with no success.
2). I have tried doing a save as a new name.
3). I have tried creating an entirely new map with new success of downloading.
4). I have tried to turn off all of the sharing for the feature services individually and within the map without success. The strange thing is that I am asked to update the sharing of layers that are not shared the in the same fashion, when I click yes to all, it continuously loops through wanting to update the sharing?
Really need to get this figured out as everything worked prior to last night and I know there was an update to the ArcGIS online overall.
Any suggestions would be greatly appreciated.
Thank you,
Mike
MiaogengZhang
Mike Bruening We just have one known issue with ArcGIS Online update.
If the layer is configured with attachment and it is empty, it will have download issue. Tomorrow morning we will release a fix for this. As a temp workaround before tomorrow's fix, you can add a dummy record with attachment to the layer, it should address this download issue.
MiaogengZhang
StevenCotterill
*apologies, first posted in wrong thread.  Moved comment here.
Hi Miaogeng,
Would this error also impact downloading file geodatabases?  I have a standard python script that creates a replica and downloads nightly and last it failed, the script executed but no replica was created.
MiaogengZhang
The fix is released. Steven Cotterill‌ I am not sure if it impacts downloading file geodatabase. Since the fix is released, you can try and see.
DanielleKulas
Thanks for the fix, map download is working now.
Question... is there an email listserv or something we can subscribe to for collector/agol bugs like this? It would be nice to know about these issues as they arise instead of stumbling across them in our own testing or finding out from staff that something isn't working, then rooting around in the online help/forums.
MiaogengZhang
Danielle,
Call Esri support will be the best approach, I think.
