Collector not saving new point geometry, only saving new attribute data
1067
04-18-2019 02:22 PM
deleted-user-AyQ-Iok8btBJ
I am having an issue when I collect points in the field, I add a new point using my gps location, fill in all my required attribution, take a photo, and hit submit. It submits successfully but the point geometry does not draw or show up in the map. Back in the office, the point still doesn't show up in ArcMap but the attribute table contains a new record with all the data I filled in for the new point. This process works fine in the Classic Collector app.
Any ideas what could be going wrong here?
Figured it out: Certain 'ESRI' fields were hidden in the webmap so they would not appear as in the popups. ObjectID and Shape fields specifically. Once these were visible again, Collector worked as expected.
