Collector crashes when creating a simple point feature
5310
18
01-03-2014 06:55 PM
IB1
I created a simple point feature class called Poles.
There is a field called Type with a domain and the choices, Primary and Secondary.
I've created a couple feature templates for each Type symbolized differently.
I published the feature class in ArcMap as a service via our ArcGIS Online account.
I added the feature service to a map in ArcGIS Online and saved the map and shared it with my organization.
I then opened the map on both my Android tablet and phone. I can view the map fine and view any existing attributes but the moment I go to create a feature it crashes and gives me the following error:
Unfortunately, Collector has stopped.
And that's all it says.
Any idea what's wrong? I am using the following coordinate system:
The coordinate system is NAD_1983_StatePlane_South_Carolina_FIPS_3900_Feet
Is that the problem?
RussRoberts
Esri Notable Contributor
Did you enable sync on that service?
IB1
Where exactly do you do that? I didn't see that option when I hosted the data via our server.
When I was testing the process and hosted the data via AGOL, I saw the sync option.
But can you confirm for me that geometric networks do work with the Collector app?
RussRoberts
Depending on the version of desktop you are using you should see it when you are publishing the feature service and you are enabling the capabilities for the service. And the Collector does not fully support geometric networks currently.
Russ
IB1
Russ
I'm running Desktop 10.2 and Server 10.1 and I didn't see it there.
So what happens when you try to edit/create features that participate in a geometric network?
Would you get there error I got above?
I'm trying to figure out if it's the geometric network or something else.
RussRoberts
Are you able to perform the same edits in the web map and see that data sync with your database? Also try refreshing you web page after you make the edit change to see if it is still there in the web map.
I am checking out my network test now and will update the thread when I am done.
Update:
I did a quick test with a sample network and my edits submitted without any issue.
Russ
IB1
Update:
Russ
When I go to the AGOL web map and try to create one of the features that participate in the geometric network, it just doesn't create the feature when I click.
The mouse has the little "Click to add a point" text, but it just doesn't do anything.
RussRoberts
This could mean there is an issue with the service and the server is not accepting the features.
Russ
IB1
Russ
What's the easiest way to share my Collector map with you?
RussRoberts
You can invite mobile_org into a group and I will use that account to view the maps.
