Collector app 18.0.1 sync error
5381
6
04-11-2018 03:24 AM
SteveTaylor7
Getting a sync error on version 18.0.1 Android Collector. App crashes. Fix is to unattach base map then reattach. Then app will edit and sync again. Please investigate and remedy.
MiaogengZhang
Steve,
Can you describe your environment (ArcGIS Online/ArcGIS Enterprise, hosted feature service or ArcGIS Server feature service, basemap, the security)?
Does the sync error provide more details?
What do you mean "unattach basemap then reattach"? Do you use basemap tool to switch basmap or something else?
-Miaogeng
SteveTaylor7
Hello Miaogeng
We have an enterprise account ACTGOV in Australia.
Collector app is used on device or offline. That means we attach a tiled
base map to the feature layer. Then edits have to be synced to ArcGIS
on-line.
The fix to this bug (Collector on device map crashes when sync attempted)
is to select manage - remove features only. This unattaches the base map
from the map concerned. Then you select download and choose the base map -
and then select download again to reattach the base map. Then sync of new
edits will work.
The bug was introduced by the update to Android Collector app version
18.0.1. So the developers will have an understanding of why this has
occurred.
Regards
Steve Taylor
MiaogengZhang
Steve,
Thanks for explanation. Here is my understanding of your environment. Correct me if I am wrong.
- Use ArcGIS Online environment with ACTGOV enterprise account
- Use ArcGIS Online hosted feature service
I have additional questions:
1) Is tiled basemap hosted in ArcGIS online or other place?
2) Do you remember the elapsed time between downloaded and sync error happening?
3) If you sign out the account and sign in again, does it fix the sync issue?
-Thanks
Miaogeng
SteveTaylor7
Yes Miaogeng we
Answers to other questions:
1) Our base map is not the issue. It gets attached to maps that can be
taken off-line or on-device. The bug has only occurred after the recent
update by esri developer of Collector app to Android version 18.0.1.
2) App crash occurred after update.
3) Fix is as follows:
Select manage - remove feature layers only - download - select base map -
download - see this video of the procedure:
https://drive.google.com/open?id=1i0RAMVB1HrfY6B0mANQz0cCY59UnenDC
I am advising staff and contractors not to update to 18.0.1 until bug can
be resolved. As issue does not occur with previous version of Collector app.
PaulZanni
Same issue here and with the same configuration mentioned by O.P:
- Use ArcGIS Online environment with enterprise account
Additionally, when a map is successfully opened on the android device (not in offline mode), unable to collect features, ie, no "+" symbol appears to begin the collection process.
Both hosted feature layers appear in the layer list but cannot be turned on.
All feature services in use work perfectly on all other devices, iOS, desktop etc.
jorisfrenkel
I am just wondering whether this bug has been solved in the meantime. I am asking because I am experiencing an issue with synchronizing certain JPG attachments that looks a bit like this one.
Regards,
Joris
