Change co-ordinate format / projection of dropped pin?
3893
12-01-2014 09:30 PM
GISSupport3
G'day All
When a pin is dropped on the screen, a Lat / Long co-ordinate in decimal degrees is returned,
Is it possible to change this to degrees, decimal minutes or degrees, minutes, seconds?
And / or is it also possible to have the result as a projected co-ordinate?
Thanks
GISSupport3
Any progress on adding the above functionality / configuration option?
PeteCrosier
The only way I've seen to influence this is by changing the basemap in Collector to one using a different coordinate system - we use a basemap in British National Grid and Collector returns coordinates as X / Y pairs when using this basemap.
GISSupport3
Hi Pete
Our area covers three zones, so we wouldn't run three copies of each cache.
I can get most users happy with Lat / Longs though they all want the co-ordinates displayed in anything but Decimal Degrees.
Degrees Decimal Minutes and / or Degrees Minutes Seconds are standard for other business areas we work with; ie aviation.
