Can't enter in information for feature in disconnected environment.
1114
03-27-2014 02:30 PM
TysonTaylor
I'm testing collector's in a disconnected environment, when i download a feature class to my Iphone it works fine and when i begin to collect a new feature type a polyon it works;however when i try to enter in attributes for the feature some of the fields have domains I can't enter in anything.  Doesn't allow me to type or choose any values from the pull-down.
any ideas.
thanks.
RussRoberts
Esri Notable Contributor
Does your service have editor tracking and ownership capabilities enabled?
Russ
PaulOmute
I have the same problem
RussRoberts
If you cannot enter attributes with the iOS version of Collector with the disconnected version of a map it is probably due to editor tracking and ownership controls. The app currently does not support editor tracking and the ownership controls if you disable those properties on the service through the item details and re-download the map it should work as expected.
Russ
TysonTaylor
Russ
I enabled editor tracking and ownership capabilities on the feature service.  That was the trick thanks for the help
