Can not add attributes offline??
646
03-28-2014 04:22 AM
PaulOmute
I have created afeature service that works perfectly well offline- I can create features and add attrubutes (including coded/listed values).
However, offline all  my feature fields are greyed out.  I can only add /submit features but not any attrubute???
RussRoberts
Esri Notable Contributor
This is probably due to you having editor tracking and ownership capabilities enabled on your hosted service. If you disable these capabilities on the service the attributes should be editable.
Cheers
Russ
