Autofill/Predictive Text Function?
6994
8
08-20-2014 06:18 AM
FrancisSenyah
Not sure if this is device or App specific, but one of our users has asked whether the App can include a Predictive Text feature, allowing a quicker way of populating fields that require common answers, without having to scroll through the dropdown options, a particular time-saver in heavily populated dropdown fields.  Haven't seen much about this online or on the forums so would be great to find out if it's been looked at all.
AnthonyGiles
Honored Contributor
Have you looked at the Repetitive feature collection ability:
http://blogs.esri.com/esri/arcgis/2014/06/05/repetitive-feature-collection-made-easy-with-collector/
Or if you have common values for particular fields can these not be set to be the default values in your feature class.
Regards
Anthony
FrancisSenyah
Thanks Anthony, yes I have had a look at the continuous collection options which are of use, but not quite what we need.  I just wondered if there was anything a bit more intuitive we could make use of but no worries, thanks for the response.  Cheers.
by Anonymous User
Not applicable
Any luck with this Francis?  I am looking for something similar. My Collector users need to enter a streetname, and would like not to have to type the whole streetname, but have it pop up after they type a few letters.
FrancisSenyah
Hi Brendan,
Unfortunately not, besides the suggestions above I am not aware of a more sophisticated option with the current release.
ScottPrindle
Hey Francis,
This sounds like it could be a good suggestion for the future of Collector for ArcGIS. Have you taken a look at http://ideas.arcgis.com to see if it already exists? If it is not already there, you can write it out and tag it appropriately to get further input from the community. Let me know if you have any questions.
Scott
by Anonymous User
Not applicable
Did this get added as an idea?
FrancisSenyah
Hi Kate, I didn't personally get around to adding it unfortunately but it is still an idea that we would benefit from so I will take a look at adding it shorty.
by Anonymous User
Not applicable
Sounds good - let me know when you do and I can vote up or can add myself.
