Attribute Display Not Using Configured Popup on IOS
2248
01-13-2014 07:50 AM
RichardAddison
Hi: I've been experimenting with Collector on both an Ipad and Android device. On my test map application, I have configured the popups for my main data layer to show only a few of the many data fields available in the layer. I have also changed the field display order and modified some of the displayed field names. Everything looks great on ArcGIS Online. It also looks great on my Android Device. However, when I access the attribute screen for the same map application on the Ipad, I get the default attribute display for the layer - all the fields, no custom field names, default display order.
Is there something I'm missing on the IPad? Any way to force it to reload the entire map app? I really like the IOS implementation of Collector, but need to be able to properly display the attributes.
Rich
RussRoberts
Esri Notable Contributor
Can you share your map and I can take a look?
Russ
RussBond
I've had the same issues.  Anyone have a solution?
