Attachments in Collector will not sync, numerous devices
3504
06-27-2014 08:49 AM
ThomasColson
I have a working collector App on through my organization AGOL account. A simple point feature class. Works great in desktop, AGOL, etc, including adding attachments (photos). Works great on numerous mobile devices in collector, as well. Can record a new point, synch, edit delete points, synch, add 10 points, synch.
It all fails when I add a photo attachment. Add a new point with attachment, will not synch. Edit a point and add attachment. Will not synch. Photos are about 2.5 mb. Of course it fails with a very informative error message:
Sync Error a Error occurred while synchronizing edits. Operation rolled back.
1st Device: Iphone 4s, IOS 7.1
2nd Device: Garmin Monterra Android version 4.0.4
On the iphone, if I go back an edit the point and delete the attachment, it will then sync.
On the monterra, even if I go back and delete the points that had the attachments, it will not synch. In other words, on collector for android, even if you remove whatever edit is causing a sync to fail, you're screwed. Just lost your days worth of data collection.
ThomasColson
...removed Editor Tracking from the FGDB and republished....same error.
ThomasColson
...added globalID to the feature class....republished....seems to work now
Cameron_Smith
I am having a similar issue, unless I use the disconnected editing feature with my iphone 4s, I am not having the issue from android, still need to test on iphone 5
