Are there plans to add a legend to Collector for iOS?
3351
01-12-2016 07:26 AM
BradKiep
Are there plans to add a legend to Collector for iOS?  We are stuck in the green app because many of our workflows require the field workers to edit existing points.  We don't let them add new points or edit the geometry of the existing points.  There is no way in Collector for them to know what each symbol means and that leads to frustration and mistakes.
Kylie
by Esri Regular Contributor
Hi Brad -- Yes, it is definitely in the backlog for both iOS and Android.
Esri Education Team
RandyBurton
As a work around, you can configure the pop-up in your map to display the data in the field you are using for symbology as part of the pop-up title.  This field can be made read-only (check display and uncheck edit) if you do not want your collectors to edit this field.  If the data is a coded value, consider using a domain to give it a meaningful description.
Kylie
Esri Education Team
BradKiep
Thanks Kylie, that is good news.  I'm guessing there is no time frame for when to expect the addition of the legend?
Thanks again.
Kylie
No, sorry, I don't have a timeframe on this one.
Esri Education Team
