ArcGIS Collector iOS app - per App VPN and SSO
909
11-21-2021 09:04 PM
TomJukic
Hi ESRi Community Members,
I am looking for some help in relation to ArcGIS Collector on iOS.
We are looking at deploying the ArcGIS iOS apps to managed devices with some of the AppConfig parameters. At the moment we only user 'portalURL' to pre-populate the URL when user's launch the app from their iOS device. We also use a VPN with this configuration so when the ESRi app launches it tunnels the connection to our internal server.
We use Microsoft Intune as our MDM platform and have recently started testing our ArcGIS Dev environment with Azure AD authentication for our single sign on.
When testing the single sign on in a web browser on a Windows device - the SSO works as expected.
If I set up a managed iOS device with a per-app VPN and launch an ESRi app, it loads the sign in screen. However, when I select the option to sign in using Azure AD authentication, an error occurs stating "Frame load interrupted"
I am wondering if anyone has set up an ESRi managed app with AppConfig, per-app VPN and Azure AD auth?
Any help is much appreciated.
