Add Location Profile as GNSS Metadata Attribute in Collector/Aurora
1918
11-15-2018 02:55 PM
Status: Open
WillAnderson1
Option to Add "Location Profile" as Additional GNSS Metadata Attribute in Collector/Aurora
Maybe there's a way to do this already programmatically (if so, please share!), but it would be very helpful if whatever Location Profile (transformation) is used while collecting GPS data with Collector/Aurora is written to a GNSS metadata attribute (as already done for estimated Hor/Vert accuracy, #sats, Fix Type, Diff Age, Station ID, etc.).
Knowing what location profile was used would help immensely when/if - back at the office - an analyst has to piece together when corrections from an RTK or other network were used or lost, and could then fix/project only the necessary features. For example, our users always use a web map in WGS84 Web Mercator, but collect data using an RTK service in NAD83. If/when cell service is lost temporarily, the lat/long/alt of any collected features is written in WGS84 (not NAD83). Note this has been the case even when the Fix_Type is still RTK-Float/Fixed and an RTK station is written in the Station_ID, so - unfortunately - knowing the Fix_Type and Station ID is not enough in some cases. Our current workaround is to set an alarm in the RTN corrections app that alerts the user that fix type has changed to DGPS (as long as they set the alarm is set correctly and they can actually hear it over environmental/workzone noise), but if the hor. accuracy is still within the user-defined threshold, they can still collect features, those features are written using a different projection, and no one is the wiser.
Perhaps more importantly, we in the office don't have control over whether every field user chooses and uses the correct location profile. Again, if the Location Profile were written as a metadata attribute, we could easily fix/project features as needed.
I would hope this would be a relatively easy addition to the metadata fields(?)
Thank you for your consideration of this idea.
2 Comments
EricStetser
In addition to the transformation settings in the profile, collecting the vertical offset in the GNSS metadata fields for each point would be very helpful.
JustinReynolds
This is critical information when troubleshooting your z value.
