Hi Guyes,
Could I find ( Vertical Exaggeration ) in cityEngine ?
It's in ArcScene in Scene layer properties . ( see attachment )
Could you explain why you need the vertical exageration on CityEngine?
There are others options to represent the same on CE
Hi Luiz,
Vertical Exaggeration give me a chance to display more deference between tops and bottoms in Satellite imegry .
But in CE when I add the Satellite imegry on top of DEM it look like a flat area which is not normal .
I hope you could nuderstand what I mean .
Select the elevation layer and change the code in the bottom box, like attr elevation = map_01(pow(brightness,2), 0.0, 100.0) + elevationDelta.
it's work .
Thank you
