Using block subdivisions from Street graphs on my own polygons/road networks
1461
07-31-2024 08:20 AM
AleksanderAStysiak
Hi
I need to model massing scenarios for city development.
I have big lots to work with that I need to split into smaller parcels for later building extrusion.
When using street graphs tool the blocks are created automatically and there are several subdivision options - recursive, skeleton etc.
Is it possible to apply those subdivisions to my lots without tracing roads manually?
in other words - can I apply subdivisions to an imported polygon?
thanks!
PS: I saw many questions touching on parcel splitting code - has ESRI released anything on this topic?
plfontes
Definitely. You can apply the same subdivision modifier on your imported shapes.
Select the desired shape and then menu Shape > Subdivide.
Regarding parcel splitting code, you can play with splitAndSetbackPerimetersetbackPerEdge, or the simple split operations. Not exactly the same outcome but you can get a lot of work done with these.
Hope this helps.
Cheers
plfontes
Hope this helps.
Cheers
AleksanderAStysiak
awesome! thanks for guiding me to the right tool. Appreciate it 🙂
