Terrain is invisible in WebViewer
3457
09-19-2014 07:03 AM
IonutAlixandroae
Hello,
I have a problem when exporting a scene, I select all the layers and after I export them and also the terrain ( Backdrop state in per layer options) and when viewing in webviewer the terrain is invisible.
It worked last times, but today I can`t figure it out why( It worked before I imported a shp file into scene - point type which has 2 text type attribute fields)
You can check the scene at : http://www.arcgis.com/apps/CEWebViewer/viewer.html?3dWebScene=271e1f4492d4499db243d6517bc8e65b
Any solutions??
Thanks !!
MatthiasBuehler
in the 2nd export settings dialog, is maybe the layer deactivated ? that sometimes happens ..
is it a standard terrain that you try to export ?
let me know.
m.
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
IonutAlixandroae
I think it was a bug because now it`s working....
Thanks !!
